Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Oil pan and cam housing
Old 10-03-2015, 05:05 PM
rinja64's Avatar
rinja64
rinja64 is offline
Default Oil pan and cam housing
Ok, this might sound dumb but I looked through my maintenance manual and cannot find what the following two hex head threaded inserts are -
Got a 2015 Limited Low - Next to the oil drain plug is one of the threaded inserts. On the cam housing, under the bike, just forward of the oil drain plug is another threaded hex head insert.
They both look like additional drain holes for their area. Would that be correct?
Thanks,
Old 10-04-2015, 05:49 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
It is routine for manufacturers to drill holes (and add features) for stuff that isn't included on every model. It is cheaper to do that than deliberately miss them out on some units. If there is nothing there on your bike, then there is nothing to worry about! There are quite probably other features on your bike that aren't used for your model. For your amusement you can use one of the on-line parts websites to look at other models, to see if you can spot which ones use those features!
Old 10-04-2015, 08:49 AM
rinja64's Avatar
rinja64
rinja64 is offline
Morning, Thank you GR - More information to make me dangerous... This link is very helpful. Have a great day...
Old 10-04-2015, 08:56 AM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
It's a beautiful afternoon here and I am tinkering on my Sporty in the sun!
Old 10-06-2015, 11:03 AM
djl's Avatar
djl
djl is online now
Received 2,032 Likes on 1,500 Posts
Thanks,
The hex head threaded insert next to the oil drain plug is the location for an oil temperature gauge sensor. The insert under the bike is an opening into the crank case sump to drain the sump. The only reason to remove the case plug is in the event you believe the motor is "sumping", you can drain the sump to confirm if sumping is an issue. Sumping can be the result of an improperly aligned or performing oil pump or the seal between the oil pump spigot and the case is bad. Either of these conditions can result in the pump failing to "scavenge" oil from the sump which causes the crank case to fill. When this occurs performance drops off, motor heats up because the crank wheels are fighting the resistance of an oil filled sump; like you trying to run in waist deep water.
Probably too much information but one thing sort of leads to another; you probably would have followed up with "what is sumping"; so just saving us both some time.
59griff
EVO
30
03-27-2016 08:02 PM
exhausted
01-30-2014 09:12 PM
IM2FA5T4U
06-17-2013 09:19 PM
Lone Dawg
03-26-2013 03:40 PM
green hd
10-30-2012 07:45 PM
Quick Reply: Oil pan and cam housing
