Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Anyone identify this plug?
Old 02-07-2016, 07:07 PM
Jaybarinc's Avatar
Jaybarinc
Jaybarinc is offline
1st Gear
Default Anyone identify this plug?
This plug in the engine case is leaking oil pretty bad.
It's small black rubber plug
Anyone know what this is and how I can fix it?
In the picture you can see it just above the oil line on the case cover. It's a black dot.
Right next to the bolt in the case is a little black rubber plug
Old 02-07-2016, 08:22 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
First we must identify the year and model...right?
Old 02-07-2016, 08:26 PM
Jaybarinc's Avatar
Jaybarinc
1st Gear
Yes sorry
91' 883
Old 02-07-2016, 09:10 PM
Olie's Avatar
Olie
Olie is offline
Well, it's obviously on the gearcase but the service manual I'm looking at doesn't say anything about a small rubber plug down there. Could a previous owner put it in due to punching a hole in the case by accident? Here's the link to the manual
http://www.carlsalter.com/pdfs/Harle...e%20Manual.pdf
Old 02-07-2016, 09:16 PM
Jaybarinc's Avatar
Jaybarinc
1st Gear
I'm beginning to think that there was a hole or crack that was drilled and a rubber plug was used because I've scoured the manual with no mention of it.
If that is the case what would be the best remedy...
Tap it and put a bolt and gasket?
Take it off and weld it?
Any ideas?
Old 02-07-2016, 09:23 PM
Olie's Avatar
Olie
Olie is offline
The options can be many but the first and best one is to replace the case. I know this isn't what you would like to hear but whatever caused that hole wasn't suppose to. At a minimum I would pull the case and see what the inside looks like. If you have a good indy shop around, take it to them and see what they say. Might be able to "plug" it with a more permanent solution. Nice thing is, it's not under a lot of pressure. Does it leak a lot or just drip out?
Old 02-07-2016, 09:31 PM
Jaybarinc's Avatar
Jaybarinc
1st Gear
When it is running it leaks a lot. Probably a drop every 5 seconds
Old 02-07-2016, 09:34 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Take it off and have it welded or replace it.
Old 02-07-2016, 09:42 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,925 Likes on 3,023 Posts
Seal it, it's not suppose to be there. Does the drain plug come out? Maybe it was put there because the drain plug was/is stripped?
Torpedo1
01-29-2019 10:30 PM
stal94gt
02-09-2016 05:27 AM
dave713
11-01-2015 01:54 AM
eddiepoindexter
09-07-2012 10:24 AM
HDF Tech
Engine Mechanical Topics
10-14-2005 12:21 AM
Quick Reply: Anyone identify this plug?
