'07 RK:wasn't lifter noise, broken shoe instead
I bought the RK in Oct. It had a slight lifter noise (I thought). Noise steadily got worse, so I checked out the Forum. Harley C lifters and SE lifters seem to be known problems. I didn't know what brand were used during the 103 install 14K ago. I put in the VThunder lifters. No help in noise. A mechanic friend told me to check the compensator which is another known problem that I didn't know about because I'm relatively new at this twin cam thing. I was surprised when I pulled off the primary cover and found a broken tensioner shoe. Shoe was adjusted all the way to the front and the mounting bolts were loose. I could unscrew the back one with my fingers. Is there anything else I should look at while I'm replacing the shoe?
