Help to overdive the bike
Hello bikers.
I want to overdrive my bike.
The bike is a Flht Electra Glide 2001 with stage 3 kit 116 hp on backwheel and a lot of rpm.
I'm thinking on changing my front pulley to a 34 tooth from standard. Is that a good way to lower the rpm? Do I have to change the belt to, or do the standard belt fit. Are there a cheaperway to do the overdrive?
Thanks and ride safe.
Hi Johnni from the UK and welcome to HDF. You have only a little more HP than I do and I am happy with stock US gearing for my 1990 bike. It whizzes down German autobahns a treat! It might seem a strange question, but do you routinely use earplugs?
Hello bikers.
I want to overdrive my bike. The bike is a Flht Electra Glide 2001 with stage 3 kit 116 hp on backwheel and a lot of rpm. I'm thinking on changing my front pulley to a 34 tooth from standard. Is that a good way to lower the rpm? Do I have to change the belt to, or do the standard belt fit. Are there a cheaperway to do the overdrive? Thanks and ride safe.
To make the conversion, you will need HD PN 40308-94, a 25T compensating sprocket and HD PN 37707-98A, a clutch basket with 36T ring gear; bearing and retaining ring is included. If you look around in Ebay, you might find both as a lot of riders looking for more acceleration have made the opposite swap and replaced the 24/37 setup with the 25/36. If you were real lucky, you might cruise the various HD forums and find somone that wants to swap.
I think if you are currenty running th 24/37 primary gearing and convert to the 25/36 primary gearing, you will find the 3.15 final drive to your liking. JMHO.
http://twistgear.net/
By contrast any increase in gearing will reduce torque in all gears and negate the expense of tuning your engine, so while reduced engine speed while in top gear might seem attractive, as djl points out, performance in all gears is reduced. Both Harley and Baker make 6-speeds that fit your bike, which will keep stock lower ratios and provide a higher 6th gear.
Even if you listen to music, you really should be using ear plugs, on all but the shortest trips! I use them routinely and while you will have to turn up the volume, you will hear your music better. Your engine will be fine cruising at speed, all you need are earplugs, to reduce discomfort.
I despair that the danger to our hearing was made known in the 70s and that the message is not getting through. They are the cheapest tuning aid known to mankind - try them!
