Rush Racing Products Performance V-Twin Exhaust — Providing the industry's most complete line of slip-on mufflers.
Exhaust smell after de-catting headpipe
Old 08-13-2015, 04:57 PM
dgb's Avatar
dgb
dgb is offline
Default Exhaust smell after de-catting headpipe
Ryan,
I have run Big Louies with 2.5 baffles in my 2012 Limited since new. I recently de-catted the headpipe and added a set of Woods 222cams. I had if dynoed but now I notice a lot of exhaust fumes while riding. Will a 2.0 or 2.25 baffle help get rid of the fumes? I thought maybe the tune was too rich, but the dyno guy says it's spot on. Also I am getting some discoloration on the front cone area of the muffler. How can I get rid of that? Thanks
Old 08-13-2015, 05:23 PM
Dan.1977P's Avatar
Dan.1977P
Dan.1977P is offline
Running lean and super hot blues the exhaust. I'd check your exhaust gaskets though. You'll get fumes up front from that too. You'll get more out back since you pulled the cat out and that's part of its job but they shouldn't be noticed when riding
Old 08-13-2015, 06:23 PM
dgb's Avatar
dgb
dgb is offline
Dan.1977P,
Thanks for the reply. I did change the exhaust gaskets and that helped to reduce the fumes. I was wondering if changing to a more restrictive baffle would also help reduce the fumes. Is there anything that will take off the bluing on the pipes. I'm hoping that after adding more fuel with the dyno will put any end to that problem. I'm OK with a hint of exhaust occasionally, but my wife however is not so much. If momma ain't happy....
Old 08-13-2015, 07:32 PM
Dan.1977P's Avatar
Dan.1977P
Are you sure whoever decatted them welded them completely? Also, are the mufflers sealed all the way too where they attach to the headers?
Old 08-14-2015, 11:49 AM
Rush Racing Products's Avatar
Rush Racing Products is offline
Check for air leaks. We don't support modifying exhaust the way you did. However, with open aftermarket head pipes, the 2.25" works best. If the smell is excessive and the muffler is discoloring, you have a tuning issue. That could be caused by a leak or the fuel management's map needs to be changed. Check for leaks at the muffler clamps. We recommend tightening them to 65 ft/lbs and using new ones.
Ryan
Old 08-14-2015, 06:35 PM
dgb's Avatar
dgb
dgb is offline
Thanks Ryan,
I think I'm going to order a new set of 2.25 baffles for my Big Louies. Can you tell me what the part number for the 2.25 baffles for the Big Louies is? I want to make sure to get the correct ones. No one in my area has the Rush baffles so I will need to find a place to order them from. Any suggestions? Thanks again.
Old 08-17-2015, 09:35 AM
Part number is 322215 and msrp is $89.95.
strickrodt70
Ironhead
01-15-2024 06:36 PM
aurimask
06-27-2015 10:25 AM
SOCALHD
09-11-2013 11:08 PM
AU_Bob
Exhaust System Topics
04-05-2013 11:05 AM
FATCAT_01
07-15-2010 02:03 PM
Quick Reply: Exhaust smell after de-catting headpipe
