Need help from a FXDFSE owner with pictures/information
Hello,
I have a '09 Fat Bob, FXDF. I've read that the tach mount on your bike(s) will directly bolt to my risers. What I need to know is how the tach mounts, how the wires are run from it? Does it drop into the top clamp/tach mount bucket and is there a backing plate with two screws that hold it in?
Is the tach 4"?
Reason I'm asking is I want to use this mount to put a 4" combination speedometer/tachometer on my bars. If it mounts using a backing plate, then I can buy a speedo backing plate which accommodates the trip reset button and everything 'should' work.
Thank you for any help you may give. Also looking for the tach mount if anyone has taken it off and has it lying around.
Matt
Is the tach 4"?
Matt
