76 FLH shovelhead upper end noise
Old 11-26-2016, 07:32 AM
randazlr's Avatar
randazlr
randazlr is offline
Question 76 FLH shovelhead upper end noise
76 flh upper end ticking noise wondering if push rods need adjusted among other possible causes and/or fixes. Anywhere I can read some info on tips, clearances and ect. for adjusting push rods before getting a service manual ?
Old 11-26-2016, 09:49 PM
E-Cigrettman's Avatar
E-Cigrettman
E-Cigrettman is offline
Get yourself a factory service manual. What all do you know about the bike that you could tell us about ? That ticking could be a variety of things IMHO.
Old 11-26-2016, 11:47 PM
randazlr's Avatar
randazlr
randazlr is offline
It's a recent buy no one admits to know the history, odometer reads 3700mi, has Elec start, springer front end. Changed leaking primary gasket, repaired short in Elec start circuit and a short in front turn signals one of which caused bike to not run. The guy who sold it said motor oil is used in clutch bath, changed that. Sounds like lifters, wrist pins or cam lobe-push rods are making ticking sound in rythum with rpm's. Gonna get service manual when $ allow just trying to get a plan going for now. Been riding an evo and a town cam the shovelhead is new to me.
Old 11-27-2016, 06:37 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,810 Likes on 3,315 Posts
This should get you there.... Just make sure you adjust them according to the TPI of the pushrod....
https://www.sscycle.com/tech-info/in...rod-adjustment
randazlr (11-27-2016)
Old 11-27-2016, 07:45 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,536 Likes on 2,872 Posts
its also the rocker arm bushings
shovels - some are louder then others
if you want a sewing machine buy a 2 cam -
if your going to ride a mans motorcycle then get use to it yea they make noise
The following 4 users liked this post by johnjzjz:
AJSHOVEL (11-29-2016), perki48 (11-27-2016), randazlr (11-27-2016), TwiZted Biker (12-03-2016)
Old 11-27-2016, 11:38 AM
randazlr's Avatar
randazlr
randazlr is offline
Hey thanks man that is exactly what I was looking for. Thanks again !
Old 11-27-2016, 11:56 AM
perki48's Avatar
perki48
perki48 is offline
Received 4,100 Likes on 1,913 Posts
And whatever you do don't go putting "wave" washers in the rocker arms.
The following 2 users liked this post by perki48:
randazlr (12-09-2016), TwiZted Biker (12-03-2016)
Matthew Peoples
Shovelhead
25
06-24-2017 08:01 PM
midget 22
Electrical/Lighting/Alarm
06-02-2017 03:00 PM
Jmc23
09-22-2016 09:38 PM
cajun1957a
Shovelhead
18
04-07-2015 10:13 PM
pnshvl68
Exhaust System Topics
10-02-2009 01:56 PM
Quick Reply: 76 FLH shovelhead upper end noise
