Tapping noise 1974 FLH
Old Apr 6, 2015 | 07:30 PM
cajun1957a's Avatar
cajun1957a
Default Tapping noise 1974 FLH
I am pulling my hair out trying to find this tapping noise in the 74 FLH. What is it. The motor has about 700 miles on it. Im running 60 wt oil with solid lifters. Compression is 150 psi in each lung, and the noise really doesn't start unitll the oil temp is about 150+ def. F. What is it? Its driving me nuts trying to find it. A stethoscope doesn't help its all over the top end. Valves are set perfect. New lifters and pushrods. When the temp of the oil is 200 deg F. its loud. Really loud. Below 150 you can barely hear it.
randy
Old Apr 6, 2015 | 08:14 PM
johnjzjz's Avatar
johnjzjz
two this happen when the pinion gear and the cam gear are out of sinc
to tight they whine -- too loose the clatter
its the reason straight pipes were inveted < just kidding
Old Apr 6, 2015 | 08:31 PM
Racepres's Avatar
Racepres
^^ Agree...and I can't decide if I hate the Whine or the Tick worse!!!!
Gonna be some parts swapping and serious experimenting to change that..
Unless the cam is obviously the wrong tooth profile...Like for a late Model.
Old Apr 6, 2015 | 08:36 PM
cajun1957a's Avatar
cajun1957a
I can live with the whine.. but that clanging sound. Can it hurt the engine. What do I have to do to see about the pinion or cam? This sucks.....
randy
Old Apr 6, 2015 | 08:42 PM
perki48's Avatar
perki48
Were the shims on the rocker shafts replaced or adjusted during rebuild? If the rockers have to much end play they will cause a rattle like that.
Old Apr 7, 2015 | 06:35 AM
cajun1957a's Avatar
cajun1957a
I never touched the rocker boxes. Guess that is where I should start. The noise seems to be toward the front more than back and high up I just wish I didn't have to pull the heads to check them
Randy
Old Apr 7, 2015 | 07:00 AM
pjb's Avatar
pjb
My 76 FLH had the cam gear whine for years. Just last month I replaced the cam gear with Andrews undersize gear. Andrews only makes 1 undersize and one oversize, along with the standard size.
It is quieter now. I hated the whine. It still has the normal shovel whine a little bit, but not the loud whine.
Old Apr 7, 2015 | 07:05 AM
cajun1957a's Avatar
cajun1957a
I don't mind the whine at all, its that clanging that drives me crazy.
randy
Old Apr 7, 2015 | 07:29 AM
pjb's Avatar
pjb
Mine was so loud it sounded like a street rod with a big blower sticking thru the hood.
Old Apr 7, 2015 | 07:49 AM
johnjzjz's Avatar
johnjzjz
before removing the heads try this - you need gloves its going to be hot
take the 2 pusrods in the front out - then use the intake push rod that is shorter and see if you can walk the rocker shaft back and forth ( right to left ) with a warmed up motor and no radio on in the shop you can hear the sound and feel how much side to side you have
you need to puch up as you walk it back and forth
the spec is around .010 so it should just about move if it clicks back and forth then go for the heads again - shims come in a couple of sizes like .003 .005 /.007
NOTE - if you find a wavey washer in the rocker assembly you need to remove them as they brake and cause all kinds if issues
