what transmission
Old 03-19-2017, 03:50 PM
lt56's Avatar
lt56
lt56 is offline
Default what transmission
hi- i'm hoping to add a kicker to my 82 fxwg. when i bought it i was told it was a four speed with a 5 speed conversion; via another thread i posted some were telling me it's a five speed transmission.
i took these pics with serial #s and brand. does anyone know if there is a way tell what i've got from the info in the pics?
It's a Sputhe and what i think is the serial # is 92101.
attached are some pics.
Attached Thumbnails what transmission-trans-cove.jpg   what transmission-trans-sputhe.jpg   what transmission-trans-shifter-linkage.jpg
Old 03-19-2017, 03:59 PM
adm's Avatar
adm
adm is offline
Received 2,460 Likes on 1,407 Posts
Surely you'll know how many gears you have?
But to me, it looks like an aftermarket 5 speed Sputhe gearbox...
Old 03-20-2017, 12:02 AM
Hurricane 68's Avatar
Hurricane 68
Hurricane 68 is offline
Default Put an Rev tech in mine
Put new rev tech mine 5spd in 4 spd case with kicker motor 75 shovel 51 frame made big difference of course mines a straight kicker only so works out. But nice to have if starter goes out and no hills to coast down. Ride Safe. Wild Bill
Old 03-20-2017, 09:23 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,922 Likes on 17,475 Posts
That second picture tells the true tale, it's a Sputhe 5 in a 4 case, uses 87 and up end cover , clutch cable and trapdoor on the trans. Another item you should be aware of is those should use the drive sprocket off an 80 to 84 FXR, it has a slight offset to clear everything and keep the chain aligned right.
As you were advised in the other thread don't waste your money on the cheaper kicker kits , Baker is pricey but the kit fits and works solidly, York and few other are less money but not the same quality product. As advised the stock ignition will give you grief as most can't tune to a one kick bike and it's a real pain in the *** to have to turn on & off each kick if ti doesn't hit the first time.
Old 03-21-2017, 07:48 AM
lt56's Avatar
lt56
lt56 is offline
very helpful info right there, thanks very much. this is way out of my comfort-zone to try to do alone. it'd be pushing it if it was a straight foreword install.
i think i'll wait on this project, but for sure, when i do it, i'll use the Baker and deal with the ignition....
much appreciation to you for sharing your knowledge. thanks
Bearlike
07-19-2019 01:35 PM
cycler
03-28-2019 03:27 PM
kopcicle
Shovelhead
10-22-2012 05:46 PM
ScottyR
11-28-2011 08:18 AM
Spitshine
Shovelhead
01-14-2008 02:31 PM
Quick Reply: what transmission
