Paughco s127a 2 up 35 rake any opinions?
Old 01-16-2014, 05:58 PM
bonesmutley's Avatar
bonesmutley
bonesmutley is offline
Default Paughco s127a 2 up 35 rake any opinions?
I have a 79 shovel rigid with longer for tubes and my frame is messed so I'm looking at a paughco s127a which is 2 up stretch and 35 degree rake rather than the stock. I like the rake cause I'm 5'9" and the longer fork tubes make it less comfortable. Anyways anyone have one and recommend it? I can't find any builds with 2 up 35 rake.
Thanks
Old 01-16-2014, 06:00 PM
bonesmutley
Pics of these are hard to find. It's between this and s128 which is the stock rigid frame with a 30 degree rake.
Old 01-18-2014, 06:03 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,021 Likes on 17,513 Posts
Built a couple using the stretched swingarm frame and the owners loved them . You do however need to check the neck for true , had one straight from Paughco be welded up 2 degrees off , the front wheel sat 3 inches offset when we mocked it up . 4 or 6 over tubes and that rig sits nice . I would also suggest tossing the chessy upper motor mount and the front lower fatbob tank mount that comes with then and making your own out of heavier 1/4" steel , the frames I got had 1/8" stamped sheet metal flimsy things included .
Fat11Lo
07-28-2013 06:42 PM
pop1
12-13-2007 10:27 PM
JimStro16
12-12-2006 12:36 AM
JimStro16
10-21-2006 01:35 AM
69sport
Ironhead
09-18-2006 09:24 AM
Quick Reply: Paughco s127a 2 up 35 rake any opinions?
