Engine tapping on my roadglide
ok, been trying to figure out what the real issue is with the tapping of the exhaust side of the front cylinder.
The bike was running just fine then was going to work and basically dropped a cylinder..barely made it home..
I thought it was the new single fire i added but it wasnt..
I pulled out the pushrods to front lifters and the exhaust lifter had a nice crack on the top where it contacts the pushrod.
So i replaced the lifters and do the 4 turns(24 flats) it calls for for the S&S easy install push rods... but the exhaust side is tapping very loud and can even see the housing moving. I took top of cylinder off and the pushrod is extremely close to the housing. when i had revved the engine it still lacks power but was not backfiring(as it did on my way home)
I even put a new lifter in again...I put the pushrod on flat surface and rolled it and still straight. the sound of exhaust is not that bad..so not sure whats going on...did not see anything wrong with rocker arm.
This is a 98 EVO 80" engine. so any trouble shooting advice wanted..
I suspect your S&S instructions also refer you to your factory service manual, which you should follow faithfully. If you have a decent local indy you could call by and ask him to take a listen to your bike, to diagnose or confirm what may be wrong. Sounds don't travel well over the internet!
Try re-aligning the pushrod tubes to center the pushrods. There is some give in the alignment and you can move them using your hands. Also verify that there are no old O-rings still in place (not removed) that may be causing problems.
None of this should cause lack of power, so recheck your pushrod adjustment.
