Floorboard insert
09-28-2007, 08:09 AM
Floorboard insert
Floorboard rubber insert is loose.Do you just push until **** pop in holes or is there a trick to this?
09-28-2007, 08:17 AM
RE: Floorboard insert
Yes, just push it in until the rubber pops out. That's what I did to mine! Use a WD40 to make it a little slippery.
09-28-2007, 09:07 AM
Yep, a little wd40 should do the trick. If not, grab hold of it with a pair of needle nose pliers to pull it through. That rubber is pretty durable.
mhud
02-18-2013 02:06 PM
harleyrider000
12-01-2012 07:38 PM
streetglidetroy
12-29-2011 05:56 PM
steamer454
09-05-2008 06:08 PM
Chilhowee
11-03-2007 09:02 PM
