Removal of brake pedal and shifter
RE: Removal of brake pedal and shifter
yep! my Fat Boy's stock brake pedal was bolted from the bottom. the stock shifter had an allen-head bolt running through the middle of therubber pedal.... well, the new ones do too. however, I changed the shifter pedal on an '07SoftTail Standard - and just cut the rubber off enough to get a pair of vice-grips on the bolt.
ORIGINAL: dlrshort
I bought a new nostalgic brake pedal and shifter and was wondering about the best way to remove the stock pedal and shifter. It looks like the best way would be to cut through the rubber and gain access to the attachment hardware?
ORIGINAL: Crusher
I'd just rubber band an M-80 to the brake pad and let it do it's work................
ORIGINAL: dlrshort
I've just replaced my shifter pedal for a Willie G. Skull, pretty easy to do. I've removed the old one, which was hold there by a srew, with the new one.
But the old brake pad (rubber)... oh man !! ... I wasn't able to remove it by pulling it off with fingers between the rubber and the brake pedal (metal).
I also tried putting a plastic tool in between, felt something, but didn't help... maybe I don't have enough strenght in my fingers
So I cutted it ! Once appart, I founded out why it was so hard, some kind of bumb in the rubber and the brake pedal itself has a "special" shape. See pictures bellow.
Removing Rubber Brake Pedal Cover
Hi Guys,
you don't need to cut it, just lever the pad a bit with a flat blade screw driver and squirt some silicone lubricant spray (wont damage rubber) under both sides of the cover. Then you can just yank the cover off with a little persuasion. There are a couple of moulded rubber lugs in the cover to stop it from slipping off the metal pedal, this is what causes the resistance.
DHubbs
Touring Parts
02-07-2015 08:39 PM
Storm7
08-26-2011 10:05 AM
