VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Adjusting shifter and brake pedal
Old Mar 27, 2007 | 01:16 PM
CJKCyclone's Avatar
CJKCyclone
Default Adjusting shifter and brake pedal
My legs are a bit longer than what the bike was designed for...thus, I have to basically take my foot completely off the peg to press the brak pedal. It is also difficult to upshift since the shifter is so high. Is there any way to adjust these down a bit? I was able to do so easily on my softail, but it looks nearly impossible on the VRSCDX...hopefully I'm wrong. Any insight?
THANKS!!!!
Old Mar 27, 2007 | 05:25 PM
eazy's Avatar
eazy
Default RE: Adjusting shifter and brake pedal
Going off of my '06, you can adjust the shifter by removing the hiem joint for the shifter rod from the trans shifter arm and turning it in or out on the threaded end of the rod.
Unfortunately the brake pedal cannot be adjusted. Might have to fab a new one.
SWThomas
Milwaukee Eight (M8)
29
Feb 4, 2020 09:21 AM
05Fatty
May 9, 2016 09:17 AM
HD160
Mar 3, 2010 06:12 AM
J-FRAME
Oct 10, 2009 10:05 PM
larry5h
Mar 21, 2007 08:49 PM
