dyna swingarm and shocks for my softail
Who makes a swing arm that would fit. or a kit.
I doupt the stock dynas will fit but does anyone know different
Ive been thinking about this for almost 3 years now. I saw in the new v-twin that OCC has a production bike with the swing arm i need but i cant find were to buy it even went to their site but dont show anything on it or if its for sale. I just want a swingarm because the shocks are a dime a dozen should be an easy change out if i can find out what i need for the pivot. might even make it a fun ride and just something else so people can shake there head at my bike and ask why or how
thanks
thanks
RE: dyna swingarm and shocks for my softail
I doubt that anyone makes a "kit" for that kind of thing. The pivot point on a Softail is some 4 to 6 inches higher than the Dynas and even if you made an"L" shaped swing arm that would look like a Dynas. The geometery of its arc would make keeping a belt at a continuous tension levelthroughout its arc virtually impossible.
A simpler, safer, and better, if not cheaper way would be to get an aftermarket frame from someone like Daytec that's made to look "like " a dyna, but with the mountings for a Softail engine/tranny combination. That would allow you to usenearly all of the parts off your bike.
Hello,Haven't gone out yet to look at my softail, but being a retired fabricator/welder, why couldn't you use the original softail rear section as a swingarm. Mount new shocks outboard like the dana you'll have to fab up some brackets and remove the stock shocks from under the bike.Still on my first cup of coffee.Just a thought.Good luck, tom south florida.
It would take a transmission change and a lot of other things to make this happen. On the Dyna, the pivot on the swingarm goes through a bracket on the transmission. On the Softail, the transmission is hard mounted to the frame. I don't know why anyone would want to do it anyway. Just get a Dyna.
Bill
Bill
ORIGINAL: dognut
Thefender strut on a Softail is not a real structural piece, being more like heavy duty trimand wouldnever survivethe kind of loading that a swing arm shock/spring would put on it.
ORIGINAL: dognut
hdpearson13
01-12-2008 12:06 AM
