Softail rear suspension conversion
I was wondering can i change the softails rear shock system to conventional dual vertical shocks or to monoshock....ive looked all over the internet to try and find some plans ,where i should weld or cut and place new tabs.. Does anyone know at what angle i should place the vertical shocks and whereni should weld?
The entire frame and swingarm are designed around the current setup. You're looking at A LOT of fabrication and work for absolutely no gain.
Why even have a softail if you're just going to get rid of the softail? Buy a regular swingarm bike. It will be cheaper.
theyammieguy
Nov 18, 2011 07:33 AM
