V&H short shots... Need Fuel Management System?
I have an fuel injected 03 Nightrain with Stage 1 download, K&N high flow air filter and slip ons now.
Can I just swap out to V&H Short shots or do I also need the fuel pack from V&H too?
Sorry for the stupid question and thanks in advance,
Jack
Jack
RE: V&H short shots... Need Fuel Management System?
I have heard from other riders & from some tech people at the HD dealerships that the download is realy not enough of a fix, ecspecialy for a new full exhaust system. (Could just be their way of selling a SE Race Tuner) My Uncle rides a Road King with a set of slip ons on it with the SE Air Kit & the download & he still gets some pop on decel & when shifting. Do you have any issues like this now with your current set up? If so I would believe itmightget worse with the new full exhaust system. There are some manufactors of fuel management systems that come with a caned value you can put into the system depending on your motor size, air kit, & exhaust style. There are other units that require a dyno tune to get max performance and a dyno could be done with the units that come with the caned values as well to make sure everything is dead on.
I guess you could try & see at first with just the download & new pipes but if it pops alot on decel or when shifting I would get a fuel management system as soon as possible to avoid any damage to theengine due to being to lean.
Later,
Dan
Later,
Dan
