Little trouble with my 2006 Fatboy
Hey everybody! I rode my bike from Columbia, SC to Maggie Valley, NC this past weekend. All was fine, the weather was great, and the bike ran like a top. Shortly after I arrived, I started to notice something was wrong. The bike was making a bad smell and the check engine light and battery light were coming on. I traced the source of the smell (like rotten eggs) to the vent pipe coming out of the transmission. I checked, and even though the check engine light and battery light are coming on, there aren't any codes in. I only found the part numbers listed there. Any idea what's wrong here? How can I test my voltage regulator? Is the alternator possibly getting too hot and cooking the oil? I replaced the battery with no change. Thanks!!
Today was the first time I've had the bike on a trailer. I wanted to put a sign on it saying broken. I hated to trailer it..
I checked the voltage at the battery. It's putting out about 12.0 - 12.3v when running. With the bike off, the new battery reads 12.5v, so I guess it's not charging. I tried to check the ac voltage from the output of the stator (at the regulator plug) and got between 5 and 25vac. I'm not sure about that reading, though. does this mean my stator is fried? I still get that rotten eggs smell coming from the vent on my transmission shortly after cranking the bike up. any ideas?
yea, it's actually coming from the primary. I'm going to open it up tomorrow. I had the inspection cover open for a few minutes, and it stunk up my shop. I suspect that the primary must be vented through the transmission. I'm pretty sure the stator and regulator are toast. I don't want to pull out the plastic until I know for sure. I'll see tomorrow, I guess.
I checked it with the throttle pretty far open. Stator output was fairly low. My service manual says 20-60VAC is normal. I got 5-25VAC or so. I'm going to open up the case tonight after work. I expect the stator to be burned up or something..
About the starter wire, I'm fairly certain the smell is coming from inside the primary. When I took that inspection cover off, the smell nearly knocked me over. It's nasty!
