Engine light and battery light on at same time
Old 05-24-2016, 10:47 AM
MollyyGirl's Avatar
MollyyGirl
MollyyGirl is offline
Stage I
Unhappy Engine light and battery light on at same time
Hello from CO
My battery and engine light have been coming on at the same time...then going off. Checked battery connection (of 1.5 year old battery) = good.
Last two miles of trip the speedometer rested on 0...the led read outs (odometer, gas pump icon, etc.) were flickering wildly. Replaced a blown fuse, jumped her, she started up but only ran for about 5 minutes, then died. I had her towed to my garage. any suggestions?
Old 05-24-2016, 02:33 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Pitbull_Dallas is offline
Check your codes. I had both lights come on and go off for a while and then one day the came on and stayed on. It was the stator. As to the flickering, a stator can make things like that happen as the battery voltage drops and a partially dead stator is trying (unsuccessfully) to charge.
A regulator might generate a similar symptom, but I'm leaning toward the stator on this one..
Old 05-25-2016, 08:30 AM
opencaliber's Avatar
opencaliber
opencaliber is offline
Mine was doing that just before the voltage regulator went out.
Old 04-24-2019, 08:04 AM
John Hardison's Avatar
John Hardison
John Hardison is offline
Stage I
Any verdict on what this was? I am having the same issue, with the added knowledge that my voltage indicator is hovering around 10 instead of 14 while the bike is running. I am assuming stator, but this voltage regulator looks possible, too. I'd rather just go and replace the one that is causing the problem, so what was the outcome of your problem?
Old 04-24-2019, 08:43 AM
Pitbull_Dallas
Why don't you stop at Harley and ask them to check the regulator. It only takes a minute. The battery needs to be fully charged for them to get an accurate reading..
John Hardison (04-24-2019)
Old 04-24-2019, 06:56 PM
ChromeJunkie's Avatar
ChromeJunkie
ChromeJunkie is offline
Received 3,799 Likes on 1,676 Posts
Both times I lost a stator, I got both my the cel and battery light.
Tracerm
Electrical/Lighting/Alarm
08-03-2015 09:59 PM
Tracerm
06-29-2015 01:42 PM
Napalm Dog
08-26-2014 05:11 PM
1911NT
08-06-2012 06:30 PM
Jerseyrider
04-29-2010 10:03 AM
Quick Reply: Engine light and battery light on at same time
