Voltage Regulator???
BUT
you MUST check with a known charged battery and good cables...tight at both ends.
the charging system checks are on the tech board/ electrical section
mike
the VR converts the AC voltage from the stator to DC voltage and then regulates that DC voltage to below 14.8.
the VR also prevents the battery draining back through the charging system to ground when parked.
you may be right in your guess, but you have to test, you cannot assume
( and many electrical problems are simply a bad connection...which is re-newed when parts are swapped out
i posted last year on a neighbor who spent $1300 at the dealer...2 VR's, 2 stators, 3 batteries.
he came to me and within minutes I found the $12 cable that looked like this inside:
a cable rotted like that can intermittently be "open"- no connection...or present a high load...high enough to burn up a charging system
mike
