Auto Chain Tensioners...???
I read this on another Motorcycle site.....have you heard this ...cause my Harley shop
hasn't. Some dude suggested that one of the first things that need to be done to new
Harleys is change the Auto tensioner cause it....
applies way too much tension to the chain....and
fills the primary oil with metal shavings.....
said to change it to an M6 or HB125 unit....whoever sells those ??
probably bad info. .........
I installed a M6 and it performs flawlessly!
http://www.jpcycles.com/productgroup...ore=All&page=1
Quieted down the chain, it's one less thing I have to worry about in the primary area...
I'm still doing some searches and looking......
could it be ??? https://www.hdforums.com/forum/showt...hain+tensioner
http://www.haydensm6.com/m6_bt01.htm
Sorry, couldn't resist the poke! IMHO the auto-tensioner is just fine unless you're drag strip racing the bike then I could see a problem. The tensioner works by spring-loaded pressure to take up slack but cannot back back down once it sets so what you're asking is will it over-tension the chain? Yes it can during extremely hard accelerations where the chain lags. However, I haven't heard anything bad being said about them here at school, anyways, as far as premature wear, chain breakage, etc. Better things to buy than a redundant part. I've got the "old style" and have thought about retro-fitting and I wouldn't put a crappy part in my bikes.
