Fork rebuild
Old 10-17-2008, 11:25 AM
L_Brown's Avatar
L_Brown
L_Brown is offline
Default Fork rebuild
Is there a thread in this forum that shows how to pull the front forks apart to replace the springs/seals and so on. I am installing a set of rear shocks that are adjustable and I have a spring kit for the forks to lower them.
Old 10-17-2008, 11:29 AM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
Get yourself a shop manual for your bike. You will thank yourself over and over...
Old 10-23-2008, 10:16 AM
L_Brown's Avatar
L_Brown
L_Brown is offline
I would love to get a manual but now I have lost my job and need to save as much money as I can. Does anyone have a web site that will show how to do it. I found a real good video but it only shows the first step and then ends.
Old 10-23-2008, 10:26 AM
Renegade1's Avatar
Renegade1
Renegade1 is offline
Go to Progressive suspenspion website, they have pdf dowloads for fork spring kits and shock installation, but you really do need a manual. A fork seal installer is gonna cost more than a manual. Good luck.
Old 10-23-2008, 11:19 AM
chrome-dome-dave's Avatar
chrome-dome-dave
chrome-dome-dave is offline
you can use the old seal and a piece of pcv pipe to install the new seal
Old 10-23-2008, 11:52 AM
klf33's Avatar
klf33
klf33 is offline
Without a shop manual, kinda tough,
But, My 2 cents are .. remember to have some 'Metric' tools (10 mm for the brake caliper mounts, 8 mm for the bottom bolt that holds the tubes into the the lowers).
You also need an impact drive, and a small PVC tube (I got one from HomeDepot), that you will use as a 'hammer' to settle the new seals in.
This is what I needed but I did not disassemble the tube itself which requires some extra steps hope others will help.
Old 10-23-2008, 02:52 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
Take a look here. It may help some...
http://groups.msn.com/toddsharleypix...eforkswap.msnw
Mike
NY
Old 10-23-2008, 03:01 PM
L_Brown's Avatar
L_Brown
L_Brown is offline
Thanks guys
WARG
03-07-2011 04:11 PM
SecondChance!!
04-01-2010 07:08 AM
hogdvr
12-12-2008 09:39 PM
RicksFlhti
11-25-2007 02:05 AM
clayman
02-14-2007 03:39 AM
Quick Reply: Fork rebuild
