Handlebar change.......with pics
Old 05-05-2009, 01:28 PM
shootfirst83's Avatar
shootfirst83
shootfirst83 is offline
I'm installing 16" gimps next week and this thread is definitely going to help!
  #42
Old 05-05-2009, 01:40 PM
ronyd's Avatar
ronyd
ronyd is offline
good pics and post. BTW, I didn;t remove pipes to get at the xsmission cover. I just lossened pipe at the headers, and at the muffler clamps. If you use a ball type allen wrench, you can loosen bottom bolts up enough to get the cover out.
Otherwise great post ....
  #43
Old 05-12-2009, 01:01 AM
shootfirst83
Originally Posted by mojojones
Here the clutch cable has been removed.......take care when unscrewing the housing from the cover.......the threaded part is very thin and easy to break. The cable end slips out of a slot in the ramp (the round piece that the cable attaches to) after removing the large circlip. Special tools are helpful here.........that's a biiig clip! Notice the clutch cable housing O-ring......it needs replacing with a new one. Also notice the anti-sieze stick......coat the threads of the new clutch cable housing to reduce the chances of crossthreading and breaking your new expensive clutch cable's housing in the side cover. It can happen very easily........ask me how I know..........
So I ended up breaking my housing on the clutch cable... How did you get the threaded part out of the clutch release cover after it broke off? I tried hammering in a torx but it would just spin.
  #44
Old 01-06-2010, 02:44 PM
ironman's Avatar
ironman
ironman is offline
hi - Im about to install one of the HCC complete kits - I went for the 18" chubby apes complete with the chrome switch housings all pre-wired...this info will be invaluable....Thanks
  #45
Old 01-06-2010, 02:51 PM
DarkTrak's Avatar
DarkTrak
DarkTrak is offline
just gravity bleed.......just slowly squeezed the brake lever every few seconds
Dude...your bike gives me wood...is that gay?
  #46
Old 04-15-2014, 11:10 PM
SKT's Avatar
SKT
SKT is offline
Bumping this old thread to the top as this great write-up will certainly help other members who haven't seen it before.
Thanks for taking the time to document this!
  #47
Old 04-15-2014, 11:24 PM
CSS_FXD's Avatar
CSS_FXD
CSS_FXD is offline
Be very careful sliding the tank back or you will scratch the f#$k out of the rocker cover on the right side if your crossover hose clamp is stock. It rubs right along the top of your rocker. Trust me I did it.......so put a rag on top of your motor ...
  #48
Old 04-16-2014, 07:06 AM
24v's Avatar
24v
24v is offline
I cut a square of cardboard off of a box lid and placed it between the clamp and the top of the rocker box cover.
  #49
Old 04-16-2014, 07:54 PM
Pie1971's Avatar
Pie1971
Pie1971 is offline
Yup! Did the same thing, Scratch on the rocker cover.
Dutch101st
11-10-2014 02:55 PM
msamarah86
07-12-2011 08:57 AM
kdclaiborne
06-22-2011 09:23 AM
mwram03
08-05-2009 05:25 AM
KBES BAGGER
01-28-2006 01:20 PM
Quick Reply: Handlebar change.......with pics
