tach install help needed
Old 03-05-2011, 02:18 PM
RandyS's Avatar
RandyS
RandyS is offline
Default tach install help needed
Hi, posting for a buddy..he has an 05 heritage. He purchased a used tach from a guy...picture posted. Is anyone able to tell me where each wire hooks? pics appreciated...thanks! Randy
Old 03-05-2011, 08:16 PM
softail99custom's Avatar
softail99custom
softail99custom is offline
Default tach wires
If i remember correctly..... on my 99 the red was power, black was ground and yellow was signal from the coil.... I think ???????????
Old 03-05-2011, 09:09 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
Yep, Red and Black are Positive/Negative for power and Yellow is Signal.
That's the exact Tach I have. My bike is an 06 EFI so I was able to connect the Yellow wire to a the Speedo Plug. There is an unused Pin for the signal and then I used wire taps to get the power under the console as well.
If the bike is Carb then it's a different hookup for the signal.
Take a look at these instructions and see if they help.
http://www.harley-davidson.com/en_US...ts/-J04106.pdf
Mike
Old 05-21-2018, 02:54 AM
AnthonyLee's Avatar
AnthonyLee
AnthonyLee is offline
Stage I
Hi Mike i know its ages ago. but i just got this Tach. no problem wireing Negtive and positive / But where did you conect the data wire in the speedometer conector?
my bike is a softail 2005 efi
Thanks
Anthony
Old 05-21-2018, 03:51 AM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,004 Likes on 2,817 Posts
Yup, that's what mine is.
Old 05-21-2018, 05:42 AM
ole_phart's Avatar
ole_phart
ole_phart is offline
I put tach's on my Deuce and RK back in 01 / 02. There should be a loose red / pinkish wire under the console or a red / pinkish wire in a connector that doesn't have an opposing wire in the mating connector. That's where the red one goes. Yellow is power, black is ground.
Gtoyankee
Electrical/Lighting/Alarm
08-23-2014 07:56 AM
Thierry
02-24-2011 02:11 PM
ericsenf
11-19-2007 09:11 AM
BrianK
02-10-2007 07:09 PM
Randy Page
06-27-2006 07:20 PM
Quick Reply: tach install help needed
