Turn Signal Module (TSM) Location????
Just got a new Turn Signal/Security System module for my '06 Deluxe. Can somebody tell me where the OEM TSM is located on the bike? Is it under the tank or "buried" next to the Battery or ????
The install instructions just reference the Service manual.
Thanks, D
Thanks, D
See Figure 8-3. All Sohail models use a panel under the rear
fender to mount important electrical components.This electrical
panel contains:fender to mount important electrical components.This electrical
• Vehicle speed sensor:VSS (3) (651.
• Turn signal module (TSM) or turn signal security module
(TSSM) and connector (5) [30].
• Master circuit breaker (2).
• Security siren connector (6) (142).
Use the following removal and installation information to service
electrical panelcomponents.
REMOVAL
1. Removeseat.
AWARNING
To prevent accidental vehicle start-up, which could
cause death or serious injury, disconnect negative (-)
ballery cable before proceeding. (00048a)
2. Disconnect negative batte ry cable.
3. Remove right side saddlebag if present.
8.4
NOTE
Rear wheel may have to be raised slightly to allow for inner
fender removal.
4. See Figure 8-5. Remove two bolts (1) from rear inner
fender. Bend upper right corner of fender towards rear
tire and lift upward to clear hole in fender (2) from tab on
rear fork (3).
5. See Figure 8-3. Remove circuit breaker (2), speedometer
sensor (3), turn signal/turn signal security module (5)
and vapor valve (7) from tabs in electrical panel.
NOTE
If securitysiren is not installed, remove securitysiren connector
[142J from receptacle in electrical panel.
6. If installed, remove security siren (6) from tabs in electrical
panel.
7. On California models, remove canister tubing from electrical
panel.
8. Cut electrica l panel cable strap (4).
9. Remove electrical pane l fasteners (1) and remove electrical
panel by disengaging tab at bottom of panel from
slot in transmission case.
REMOVAL
1. Removeseat.
AWARNING
8.4
NOTE
fender removal.
rear fork (3).
NOTE
panel.
panel.
Iron Chief (04-01-2024)
