How to remove floor boards?
So I tried to loosen up the three large torx screws holding the floorboard bracket to the frame and could not budge them! Now what do I do?
Just think of it like this, it's just nuts and bolts. If you need snap a pic or two as you disconnect and disassemble each item...it will defintiely help you with reassembly. Take your time. If it's going to be apart for more than a little while, get you some baggies and tag your nuts and bolts in the baggies as you disassemble etc. Patience and Take Your Time. You got this brother!
Remove the floorboard (may not have to but this time it'll help)
Remove your shifter(s) levers
Remove the kick stand bolt and top cap (you do have it on a jack?)
Rotate the kick stand forward to remove the spring (remember for assembly)
Remove the 3 bolts
Remove the 3 bolts
albngore
03-01-2010 10:23 AM
