Powdercoat Primary Cover
Old Feb 12, 2010 | 12:23 PM
TedMan's Avatar
TedMan
Default Powdercoat Primary Cover
Well, dropped off the primary cover from my 09 XBNZ to get powdercoated gloss black, to match the rest of the left side of the scoot. Thought it would be a 12-20 minute job to drain fluid and remove, but didn't realize that you have to loosen the floorboard support bracket in order to get one of the long bolts holding the left side of the primary out. The support bracket bolts must have been put on with enough locktite to choke a horse, and the lower right one is in an inconvenient spot, so that I had a real concern I would strip it trying to crack it loose. Finally got it. Should go back together easy enough. Will post pix when it's done.
TedMan
hdspringer02
Apr 14, 2011 09:47 PM
oldschoolsam
Mar 30, 2011 08:52 AM
catken
Dec 21, 2007 05:28 PM
Ace07FXDL
Sep 7, 2007 02:15 PM
hogdad
May 21, 2007 02:27 PM
