La Briola Jockey Shift...pics
Old 04-12-2012, 01:41 PM
Angus08's Avatar
Angus08
Angus08 is offline
Default La Briola Jockey Shift...pics ??
I am planning on putting a jockey shift on my 08 Fat Boy. I am having a hard time trying to figure out if I want to order the shift arm longer (an inch or two).
From the pics that I see it appears the shift arm seems to be located "under" your left leg, I just don't want to have to go searching for a shift arm when I need to.
Just wondering if anyone else finds their jockey shift to short or has extended their shift arm a bit ?
Thank in advance.
Old 04-12-2012, 02:34 PM
Tx_Outlaw's Avatar
Tx_Outlaw
Tx_Outlaw is offline
Never had an issue with mine. Been running it a couple years now.....
Old 04-12-2012, 02:36 PM
Branner's Avatar
Branner
Branner is offline
Actually, I find mine is too long and would like it to be shorter. Order the kit as is and don't worry about it, you'll be fine.
Old 04-12-2012, 03:15 PM
brettnbama's Avatar
brettnbama
brettnbama is offline
I have this same issue, but its mostly my wife that complains about it....
Old 04-12-2012, 03:22 PM
jreichart's Avatar
jreichart
jreichart is offline
I built my own foot clutch setup, but I picked up a shift arm on eBay and ended up modifying it a bit. I just wanted it in a different spot, it would have worked just fine the way it came. You'll find no matter where it's located, the first few times you reach for it you'll be searching a bit, but after that muscle memory takes over and ya don't even think about it anymore. Good luck, you'll love the foot/jockey setup!
Old 04-12-2012, 05:29 PM
Angus08's Avatar
Angus08
Angus08 is offline
thanks for the replies, I appreciate it.
I will go with the standard La Briola set up.
Old 04-12-2012, 07:21 PM
blackbike_17's Avatar
blackbike_17
blackbike_17 is offline
make sure to post pictures when ya get it put on. iv been thinking about this setup for the last year or so...
Old 04-12-2012, 08:54 PM
Angus08's Avatar
Angus08
Angus08 is offline
Definitely !
Old 04-12-2012, 11:33 PM
thelawnmowerman's Avatar
thelawnmowerman
thelawnmowerman is offline
I've also been thinking about this setup, I even went one step further and bought it, LOL, its still in the garage waiting to be fitted, I just can't seem to get around to fitting it, maybe one day soon.
Old 04-12-2012, 11:43 PM
Iron Butt Springer's Avatar
Iron Butt Springer
Iron Butt Springer is offline
Might have to upgrade or is this considered a downgrade?
Quick Reply: La Briola Jockey Shift...pics
