Yeah, you may need to change the wheel bearings if there's a different sized axle, then you may need some new spacers..shouldn't be too much more than that though..
Talked to a mechanic also. He said I should just have to change bearings and check spacing. If they cant go on my bike he said he would buy them. Win win.
Thanx again.
You will have to change bearings for sure. I think it is 2000+ models have the different bearing...I ran into this when I purchased a Fatboy rear rim off ebay and put on my old Evo. They will more than likely have to cut spacers. They should be able to make them work.
2000 and up have sealed bearings, 1999 and down have timkin bearings. Change the bearings or change the spacers should do it for you. Both axles are 3/4" just different bearings.
Thanx again.
If you don't mind, please post your fitment results. That could be helpful information for others in the future.
