Front fork gap
Front fork gap
Hi All, new to forums and new to HD Forum...today i dropped my 06 FLSTNI while sitting in the garage....just saying....when i picked it up there is a noticeable gap between the risers where they attach to the bike. There is now play between the handlebars moving forward and backward....i took it for about a 30 mile ride and it seems to work as normal, however i am concerned about the play as it seems something is loose...maybe even a little vibration but hard to tell....any thoughts? (other than I am a dummy for dropping the bike )
Thanks,
Mulehide
Thanks,
Mulehide
If they aren't broken yet, that gap between the top triple tree and risers will snap the riser bolts.
You need to loctite and tighten the bolts back down or replace them if they look damaged. Also check the riser bushings for damage.
Hate to hear about you having them break off while you were riding down the highway.
It's probably the riser bushings. Mine were shot when I laid my old Fat Bob down. Replace them with the poly bushings and the play will go away. Pretty easy to do and the bushings only run around 30 dollars or so for the HD ones. The stock bushings are crap in my opinion and it doesn't take much to wreck them. The riser bolts might be bent but my moneys on the bushings
OneBlackFly
11-02-2007 11:42 AM
