Do I need New Bolts?
Old Aug 4, 2011 | 09:32 AM
Voony's Avatar
Voony
Default Do I need New Bolts?
I want to buy drag specialties 1.7" shorty risers. It says I need 1/2 in.-13 riser bolts. Can I use the ones that come with my 883C or do I need to buy them seperately? On DennisKirk.com I found 1/2 in.-13 riser bolts that are 2 1/2", 2 3/4" and 3" long...?
Old Aug 4, 2011 | 03:47 PM
HarleyScuba's Avatar
HarleyScuba
The factory bolts, '04 and up at least, are 1/2-13 x 2.5" grade 5. I would guess you could re-use them. Don't forget the Loctite.
Old Aug 4, 2011 | 04:09 PM
cHarley's Avatar
cHarley
The bolts go through the triple tree and screw into the bottom of the riser.
I would think that the bolt length should be the same regardless of the riser height.
Old Aug 4, 2011 | 04:28 PM
Sam E.'s Avatar
Sam E.
Stock ones are fine unless you have the super short risers but a guy could just space them with washers if he wanted. If the new risers are drilled and threaded deeper I always try to use as long a bolt as I can, it just makes me feel better to have more threads used.
And for future referrence to those who don't know this already; most every aluminum set of risers for harleys are threaded 1/2-13 while steel risers are 1/2-20.
Jersey Drew
Apr 4, 2016 08:58 PM
tbone4760
Apr 26, 2015 11:49 AM
Xenomorph
Feb 1, 2010 07:32 AM
chromedome
Nov 13, 2008 11:58 AM
OneBlackFly
Nov 2, 2007 11:42 AM
