Magnum clutch cable questions
Hi all: I just replaced my risers and needed a longer clutch cable. I ordered a new Stainless steel braided cable from the stealer thinking they would order the HD Diamondback SS cable (yes this was probably my fault for not being explicit) but instead they ordered a Magnum Shield Chromite II cable. The dealer said they would exchange it if I did not like it. It looks great and Magnum has a good reputation, but I have some questions.
1. When I installed the cable, I noticed a bit of cable stretch and had to adjust the cable three times. Is this normal?
2. Since this cable is rather thick, it tends to form larger(er) radius curves. The only place this is an issue is coming off of the handle where the cable wants to bend all the way over to the triple tree. Can the cable be forced into a smaller radius curve without worrying about kinking it? Will it stay or will it spring back over time?
3. I have noticed the cable pulls harder than the HD cable. Is this normal and should it improve with use?
Thanks for your help, Chris.
I realize that my riser/handlebar setup is different than yours, but, for comparison purposes, here is my clutch cable. I have the HD braided SS Diamondback cables. Be aware that the Diamondback clutch cable is only braided from the lever to the adjuster. The Magnum clutch cable is braided from the lever to the tranny.
