clutch cable lube
Old Jul 18, 2008 | 05:36 PM
hotrod351's Avatar
hotrod351
Default clutch cable lube
well i got my new clutch cable, motion-pro. im also installing the HD easy clutch ramps. i contacted motion-pro about lubing the cable but they said it wasn't necessary, if i were to try and lube it, with what and how.
Old Jul 18, 2008 | 07:42 PM
miacycles's Avatar
miacycles
Default RE: clutch cable lube
Hang the cable up by one end, open up the adjuster all the way until it comes apart, apply a light/cable lube to the top end and the adjuster, work the cable back and forth. Repeat a few times leaveing it hang. hope this helps.
Old Jul 18, 2008 | 10:56 PM
hotrod351's Avatar
hotrod351
im going to see if checker or autozone carry a liquid graphite. i assume you were in the 82nd. i was there for awhile before i shipped to the 173rd. that was way back when.
Old Jul 18, 2008 | 11:52 PM
2002flstc's Avatar
2002flstc
best cable lube I've ever used... Dri Slide, Bike Aid...
Old Jul 19, 2008 | 07:50 AM
dog155's Avatar
dog155
Dri Slide is the stuff!
Old Jul 19, 2008 | 10:30 AM
hotrod351's Avatar
hotrod351
ok. it that an online item only.
Old Jul 20, 2008 | 09:05 AM
miacycles's Avatar
miacycles
I did it the other way around, went from "A" co 4th bat 503rd 173rd ABN to 17th Cav (RECON) 82nd ABN also way back when they were in Dak To.
c50plus
May 23, 2016 08:52 AM
ConeMagnet
Sep 3, 2014 07:54 PM
Weirbt
General Topics/Tech Tips
Apr 27, 2014 07:46 AM
traildog
EVO
Jan 8, 2013 07:53 AM
danzio
Jun 5, 2011 01:59 PM
