engine run on
Old Jul 3, 2008 | 10:30 PM
jammer1's Avatar
jammer1
Default engine run on
Hi was wondering if someone might be able steer me in the right direction.92 softail put on a mikuni carb the bike is running great problem is sometimes when i shut it off i get engine run on for a few seconds.I checked the plugs they are fine could this be a carb problem or timming?Any help would be great.Thanks
Old Jul 4, 2008 | 04:25 AM
jpooch00's Avatar
jpooch00
Default RE: engine run on
Are you using the highest octane fuel available?&nbsp\\; if not, then that most likely is the problem.&nbsp\\; If you are already running high octane gas, then try running a can of Sea Foam through the fuel system over time at the rate of about one ounce&nbsp\\;added to the tank for each&nbsp\\;gallon of gas.&nbsp\\; You most likely have some carbon buildup in the cylinders that's causing this problem.
&nbsp\\;
Good luck,
&nbsp\\;
John&nbsp\\;
Old Jul 4, 2008 | 07:28 AM
HD7585's Avatar
HD7585
Idel set to high?
Old Jul 4, 2008 | 10:32 AM
jammer1's Avatar
jammer1
running preuim fuel,idle is set a 1000 RPM&nbsp\\; mechanic said retard the timing a few knotches and see if that works.not sure which way moving the timing plate retards the timing and which way advances timing?
Old Jul 4, 2008 | 01:31 PM
HD7585's Avatar
HD7585
When rpm's go up=advance..............When rpm's go down= retard............do it with engine running
Old Jul 4, 2008 | 04:03 PM
jammer1's Avatar
jammer1
Thx for the info
Old Jul 5, 2008 | 07:19 AM
jpooch00's Avatar
jpooch00
My advice on the timing is that it be checked and adjusted according to the specs/proceedures in the manual.&nbsp\\;\\\\\\; I am extremely doubtful that this is a timing issue, but I suppose that if the timing were off enough to cause the engine to grossly overheat, it could be the cause.&nbsp\\;\\\\\\; Does it ping and knock under heavy acceleration?&nbsp\\; When you check the plugs, are they dry &amp\\; sooty, wet &amp\\; oily, grey, brown, black&nbsp\\;etc?&nbsp\\; Are you sure that they're the correct plugs for the engine?&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\\ \;
&nbsp\\;\\\\\\;
Good luck,
&nbsp\\;\\\\\\;
John.
Old Jul 5, 2008 | 07:26 AM
jpooch00's Avatar
jpooch00
Boy, this site is a pain in the ***!
Old Jul 9, 2008 | 01:10 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
ORIGINAL: HD7585
Idel set to high?
+1 Or throttle cable sticky or out of adjustment leaving the idle high.
Old Jul 12, 2008 | 02:53 PM
johntheone's Avatar
johntheone
Agree with JPOOCH00, make sure the timing is factory set. Run on such as this is usually caused by pockets of intense heat in the engine continuing to ignite the fuel without a spark. Setup timing, spark gap and idle settings as per factory. start from there.
