How do I lubricate my clutch cable?
Old Apr 25, 2014 | 09:43 PM
Weirbt's Avatar
Weirbt
Default How do I lubricate my clutch cable?
My '94 Dyna wide glide clutch lever is real tight to the point I feel like I get tennis elbow from it. I want to lube the cable and pivot point and have picked up some cable lube spray. My question is do I have to remove the cable from the ball and ramp assembly in the trans to keep the spray from traveling down the cable and into my trans or is the end sealed?
Old Apr 25, 2014 | 09:51 PM
Greezey Rider's Avatar
Greezey Rider
I usually take the cable off of the bike and hang it on a nail and let the graphite lube work its way down the full length of the cable.
If your cable is really binding that much, you may need a new one...
Old Apr 27, 2014 | 07:46 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Make sure it is a cable that is supposed to be lubed, some have Teflon liners that are not supposed to be lubed.
If the tightness in the clutch mechanism is something that has just occurred, I would replace the cable.
gnalen
Jul 31, 2017 01:31 PM
c50plus
May 23, 2016 08:52 AM
Whiskyjock
Jan 12, 2014 10:50 AM
traildog
EVO
Jan 8, 2013 07:53 AM
hotrod351
EVO
Jul 20, 2008 09:05 AM
