Sticky clutch cable
Old Jul 3, 2012 | 05:37 PM
barb6663's Avatar
barb6663
Stage I
Default Sticky clutch cable
Can anyone tell me how to lube my clutch cable and with what. Seems to be sticking...
Thanks for your assistance.
Barb
Old Jul 3, 2012 | 06:09 PM
Alter's Avatar
Alter
Here's a real swanky way to lube the cables
I saw a pic somewhere of someone who what looks like a baggie filled with lubricant elastic banded onto the cable, tied shut, lifted straight and left overnight to seep into the cable. I don't know what lubricant exactly to use but you shouldn't use just any oil or it becomes sticky and a dirt magnet over time.
Old Jul 3, 2012 | 06:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The cable may be frayed. Disconnect the cable at both ends and see how it moves.
Old Jul 3, 2012 | 06:20 PM
jreichart's Avatar
jreichart
Get a graphite cable lube at the dealer. It'll have a long needle that you can push into the cable a bit and squeeze the lube in. You'll pull the lever to the grip, insert the needle, and lube away. Really pretty simple on the clutch since the end of the cable is accessible with the lever pulled, the throttle cables require a bit more work.
Old Jul 4, 2012 | 08:09 PM
oct1949's Avatar
oct1949
watch this..
c50plus
May 23, 2016 08:52 AM
Weirbt
General Topics/Tech Tips
Apr 27, 2014 07:46 AM
40 Knuck
Mar 9, 2010 08:04 AM
msb5201
Jan 4, 2009 04:19 PM
srawden
Apr 3, 2006 07:50 PM
