Shotgun Shock install on Breakout
I ordered a SS for my breakout and want to hear from other Breakout owners who have done the install. How have the installs went specifically on the Breakouts. Im looking for any info i can get from breakout owners that could make my install easier. It seems the install is relatively easy but you guys gotta have some help full tips and bits of info right?? I have done a search on here and have read a lot of SS install threads and it seems most have no problems but I would like to hear about some of the little minor problems i may run into. Thanks in advance for any info you can share with me. Super amped about getting my Shotgun and wanna be as prepared for my install as i possibly can.
I have not found any Breakout specific install threads, thats why I started this one. I have noticed there are a number of people on this forum that have breakouts with the SS and I'm hoping they will all chime in with their install experience.
It sounds to me like JD has made a custom bracket for the switches for the bikes that have the grenade instead of the horn. I got a email after I ordered asking if i had a horn or the grenade. Maybe when you ordered your SS didn't have the custom brackets??
Install is easy if you have a lift and a second person. 24v and I installed mine in under 2 hours. Didn't do a how-to but it's not hard by any means.
1) Remove OEM shocks
2) Remove emission hoses (there are two hoses and you'll know which ones they are because the block the mounting location of the compressor).
3) Before tightening anything down, route the electrical wiring all the way to the + and - terminals (mine barely fit)
4) Find location to mount the switches (curious if JD made a new bracket for grenade since the bracket provided with mine won't work at grenade location)
5) Tighten everything down
6) OPTEST the switches and learn what settings are most comfortable
Enjoy..........
Oh, and do yourself and everyone else a favor and document your install (creat a how-to thread) so that anyone else who's thinking about installing one has a tutorial that you made.
Best wishes!
Enjoy..........
Best wishes!
Do you have ABS? If you don't have ABS you shouldn't have to drill anything. Mine bolted right up to the location where the ABS would normally go. If you have ABS then it's a whole different animal.
