Narrow Apes for my Heritage Springer??
Old 04-23-2014, 09:57 PM
asheborogn's Avatar
asheborogn
asheborogn is offline
Question Narrow Apes for my Heritage Springer??
I like the burly brand narrow apes but will they fit? If not what will w the narrow classic look w the correct knurling on the bars? Any pointers/ part numbers/ pics will be appreciated
Old 04-24-2014, 10:17 AM
Redbeard719's Avatar
Redbeard719
Redbeard719 is offline
Received 1,220 Likes on 545 Posts
You'll find that you can replace the top tree plate with the Fat Springer Adapter Plate 2 from Carlini Designs - it's chrome so it matches right up. Once you do this, you can run any regular riser of your choice, and then you can run any regular handlebar.
Regular risers allow you to use a 1 piece top clamp, which will hold the bars better too. Springer risers are known for having the screws strip too.
As for narrow apes, have a look at the LA Choppers Nice Curves. I always suggest them for the springers because the bottom of the bars is no wider than the forks. They fit the bike so well.
Good luck!
Old 04-24-2014, 08:25 PM
asheborogn's Avatar
asheborogn
Thanks Redbeard! I'll ck them out
Old 04-26-2014, 12:35 AM
asheborogn's Avatar
asheborogn
If I get the adapter plate, can I still run the windshield.
Old 04-26-2014, 12:59 AM
Redbeard719
Yes.
Post #4 of this thread shows the two items installed. It also shows the bars I mentioned before.
Keep in mind, I had the plate powder coated. Carlini only sells it in chrome.
https://www.hdforums.com/forum/softa...ect-build.html
Old 04-26-2014, 06:52 AM
Rocker_Dan's Avatar
Rocker_Dan
Rocker_Dan is offline
Adaptor plate is the way to go
Old 04-28-2014, 10:24 AM
asheborogn's Avatar
asheborogn
Wow. Nice bikes guys! Thanks for the help. If I just bought springer bars instead of custom narrow apes, would the stock risers be sturdy enough or would they be slippage? I love the idea of the adapter plate w a solid top clamp. It just looks sturdy
Old 04-28-2014, 10:40 AM
jdub099's Avatar
jdub099
jdub099 is offline
My Zombie Performance Bender Apes are super narrow, less than an inch on either side of the clamp (like the one shown above). 10 and 12 inch are standard but he can do any height you want. I got the knurling and internal wiring options. I think they look badass, they're like a cross between z-bar style and traditional apes.
Here's a pic on my Street Bob in 12".
Attached Thumbnails Narrow Apes for my Heritage Springer??-20140422_155903.jpg
Ink83
03-30-2016 08:09 PM
XBONES54
03-06-2015 11:10 AM
JWOC
07-12-2011 07:00 AM
04Springer
04-19-2011 04:34 PM
JimStro16
03-01-2010 06:03 PM
Quick Reply: Narrow Apes for my Heritage Springer??
