No mess fork oil change
09-28-2014, 08:54 AM
Made this from 5/16 inch aluminum rod. First attempt with longer hose did not work. Need to keep hose short to prevent siphoning back to fork tube.
09-28-2014, 03:52 PM
Did you do the threading on the aluminum rod yourself?
09-28-2014, 04:33 PM
I'm confused about where the oil mess is going to go after you break the drain screw loose, and before you get this new fitting screwed in and the catch bottle and hose connected.
09-28-2014, 05:29 PM
Quote:
Originally Posted by
cHarley
me too?
09-28-2014, 09:38 PM
baka1969
yes, I have a lathe. Easy to make.
09-28-2014, 09:41 PM
cHarley
Jack the front end off the ground prior to removing the screw. A little will dribble out, no way to prevent that.
09-29-2014, 11:42 AM
09-29-2014, 12:01 PM
Isn`t there a thread adapter made for that already so those who don`t have a lathe can do the same thing?
09-29-2014, 01:07 PM
hvacgaspiping
I haven't found any....But, I'm all ears!
09-29-2014, 01:19 PM
ggruber
PM Sent
rhallman
2014-2023 Touring Models
20
08-18-2016 03:20 PM
brianmz1
08-24-2014 03:38 PM
Emdog
06-29-2011 01:28 AM
Tinmanpope
10-26-2010 02:00 AM
kjkustoms
01-23-2009 06:30 AM
