removing baffel
RE: removing baffel
This depends on how you tune it afterwards and where in the rpm band you want your most power.
General rule of thumb:
No baffles gives less mid range power 2000-4000 rpm, more top end power 4000-6000 rpm.
With baffles gives more mid range and less top end.
When you see"more" and "less" that equates to 5-30 hp & torque.
If you just want to get the highest numbers on a dyno and don't care how it runs at idlethen remove the baffles. Just remember you have less power than the baffle guy untill you wind it up.
RE: removing baffel
you lose torque period. knocking out the baffles is about the most detrimental thing you can do . all it does is make more noise. you may if your lucky you maygain a couple of hp at wide open throttle but that will be offset by the cost of replacing burnt valves if you dont re-jet or re-map the fuel delivery system.
