Engine Upgrades for the 1200
Received 2,189 Likes
but, i need to speak to hammer anyway about the pinion locker for hcr vs fine. The 536 cams came with an hcr pinion gear and my bike has fine. Do i need two lockers? Questions
No no, i appreciate it. I need all the help i can get, I'm in over my head.
The se 585 itself is list as 2014+ only. Ive been looking at the parts layouts and the only difference i see is the valve guide on newer heads... im not actually sure when that happened since i only looked at the 2007 1200 and 2014 1200.
I ally dont understand, the crank/flywheel is the same part number. And both se stage 4 kit use the same heads and cylinders. But the race set has some extra seals int picture that are not in the street kit. It was mentioned here
http://xlforum.net/vbportal/forums/s...readid=1919277
I called moco customer support got the most bizarre response from the person i spoke to. So i'll just he had no idea. I was probably just talking to the wrong person.
frostyboner187@yahoo.com
Engine Mechanical Topics
05-19-2015 04:52 AM
