Running rich question
I have a 2007 883 Custom. The bike is fuel injected and just turned over 1000 miles. The only modification is the addition of Screamin' Eagle slip on mufflers. I am going through the 1000 mile service and the only issue I feel the bike has is it smells like it is running rich. The plugs look perfect. Can the adjustment to the primary change make any difference in the fuel mixture? It is part of the 1000 mile service, but I have not checked it yet. No engine codes have ever come up. Thanks for any help.
If you haven't messed with the ECU, it is highly unlikely you are running rich. The bikes come from the MoCo at about 14.7 AFR, and that is pretty lean (ideal stoichiometry, but lean for engines). Adding the exhaust would basically leave it the same. The primary would not affect the AFR, but it is a good thing to check at the right service intervals.
