im going to go with 6 or 8 inch straight risers on my 2006 custom what do you guys find to be the best width for drag bars im thinking 30 wild1 has some nice bars that have decent pullback
I tried a couple different bars, but I kept the stock riser on my '06 Custom. I found the stock bars it came with to be OK, but too narrow. I tried the $30 "universal" drag bars from J&P Cycles, those were 32" with 4" pullback. I thought those were too wide, and they looked kind of weird at that width I thought too.
I finally settled on Biltwell Trackers, not a ture drag bar as they have an inch or so of rise, but the 30" width is perfect for me.
Not sure if that helps, but that's my .02 cents, 30" wide works for me.
i like the licks bars everyone else seems to have the chubby bars im just looking for a regular bar i have a 2006 custom so i might be able to get away with 6 inch risers with stock cables maybe even 8 inch
Your factory risers should be around 4-5" if memory serves me right. The only issue I'd expect is your front brake line. Did you check slack in your cables?
i might have to replace the brake line im kinda waiting to see what dk customs comes out with a speedo relocater otherwise im going to go with the joker
