'09 Iron stock exhaust with new air intake question
I have a '09 Iron 883 with stock exhaust. I was wondering if anyone knows a good air intake to go with the stock exhaust pipes? Or is that even an option? I have looked up a lot of info on this stuff but everyone seems to have after market exhausts. Also, if i do get a different air intake do i need to get an upgrade?
thanks
thanks
My generic 2 pence. I can't exactly vouch for Harleys (as I'm currently debating buying my first one) but generally you can put a better intake on your engines without any real issue. You'll throw your AFR off a bit and generally make the bike/car sound a bit more throaty and deep. Many people get a placebo of better performance, but its generally a tiny touch worse... depending on the vehicle and state of the stock breather...
What are you looking to get from it? A better look or actually make the bike perform a little better? If its just for the look then there isn't too much issue. You might gain or loose few hp at most, get a different engine note (normally deeper) and burn a tiny bit more petrol. I've never known of a single problem to occur from just changing the intake to something like a cone or high flow filter. Providing it is adequately filtering your air and removing any unwanted particles of course.
If you want a simple yet efficient and improved stage 1 a/c, you can't get better bang for the buck for a Vance & Hines Naked VO2 of of eBay. Then with the money you save by not buying a fancy "Designer" named a/c you can get yourself a set of XiEDs or X14iEDs to improve your a/f ratio and an Exotx Super filter for it (also on eBay). Then you'll be all set for the time, if and/or when you decide to get a different stage 1 exhaust system as well.
Received 3,941 Likes
You can't get a better intake than the Outlaw 425 or Outlaw 587.
Both will work well with your stock exhaust, all the way up to a Stage IV upgrade.
Many looks to choose from.
Will be cool to see some dyno charts of how it performs.
