How much dyna beads?
Received 4,617 Likes
If you think you still have a vibration you can feel in the handlebars above 50 mph, add another ounce to the front. Below 50, it's probably something else causing it. Also, if you can jack the bike, before putting beads in, see if the wheel definitely turns to the same spot; if it does it aggressively, I'd start out with 3 ounces - that's a fairly heavy tire on the front of Ultras. This probably wouldn't work for the rear, with that belt and drivetrain drag, it would be pretty badly out of balance to seek the same spot. There have been people saying the beads didn't work for them on this forum; I suspect they didn't use enough beads. The recommended amounts in the Dyna Bead chart is a good starting point, but can need more for some tires, especially 21" and taller, and heavier wide ones.
If the handlebars feel vibration free at 70 or more, with the clutch pulled and maybe even hit the kill switch for a moment, the front at least should be balanced very close. It's easy enough to put another half ounce or ounce of beads in later if the 2 ounces don't seem to be enough. At 70 I wouldn't let the clutch out to start it again, either, use the starter for less stress on the drivetrain.
I've deliberately run a tire without any weights or beads that was off about an ounce on a static balancer, and it was still pretty smooth at 70. But I've also had tires that were over 2 ounces off, and you'll feel those, on the front at least.
