New battery ruined?
once discharged, a battery will only retain the ability to charge to about 60% of it's previous capacity.
Charge it and use it, replace it at the first sign of weakness
make sure you charge it all the way ( charger...not a tender 3 to 5 amp charge rate for about 30 to 48 hours)
before trying to start the bike- a duff battery can stress and destroy the charging system
Mike
Mike
Depends how important that starting your bike is when you want to go for a ride. If you have alternative motorcycles, you might just be fine leaving this one in for the nonce, see how it goes. If it fails to start, just move on to another bike.
If it's your only scooter, I agree with MKGuitar, try it, no harm there, but be prepared to make a sudden change of plans. But if you are a die hard rider, and you'd die if you didn't ride, then replace it now. Chalk the cost of the new battery up to experience.
I will tell you that I've run many batteries flat in my time, recharged them...slowly... never a problem again. Were it me, I'd do the same thing with this one, keep on truckin'...but that's me, not you.
Went ahead and installed it and it fired right up. Hoping there is something to what you said.
Received 70,434 Likes
