Arlen Ness Inverted Air Cleaner - HELP
So I thought that this was going to be a simple bolt on job. Got the cover and filter out, then when using my cheapo 7/16 socket on the breather bolts, I rounded out the socket. Time to put down the beer and head to Home Depot for a $1.68 7/16 socket.
Got back to the house and the breather bolts came right out. Removed the backing plate. Now I need to remove the throttle body support bracket. According to the service manual, there are two hex bolts behind the bracket holding it on. How can I get at these without removing the fuel tank? I welcome any options.
There is enough room to get a 1/4 drive in there with out removing the tank, use your hands to feel the torque bit insert into the head and loosen.
I did the left side first, after you remove that bolt you can turn the bracket out wards to get to the right side easier.
If you want you can trim off the edges of the bracket ( enough to allow room for the new back plate ), re-install the bracket then you will have something to clip the wires back onto.
I must not have the right tools. Anything attached to a ratchet is too long. I can get an allen on there, barely, but it is long ways. Short ways won't clear the support bracket. When the allen is standing long ways, the inch long top doesn't provide nearly enough leverage to break the bolts free. Even if it did, there is zero room to turn it.
Can you post a pic of your 1/4" drive and ratchet? You said you don't have to remove the tank, but did you unbolt it and lift it?
Yep, what he said, take out the rear tank bolt and prop up the rear of the tank. It just needs to raise a couple inches. I think I used my old filter to hold it up and that was perfect. It takes a little patience. I used a hex drive socket and was able to get them out.
Good luck.
Good luck.
Thanks for your input though.
