Do I remove throttle body support bracket?
Old Mar 18, 2013 | 01:30 PM
cryan9's Avatar
cryan9
Default Do I remove throttle body support bracket?
Got an RSD Venturi Air Cleaner. Do I remove the horseshoe shaped TB support?
Old Mar 18, 2013 | 01:55 PM
glide2meetu's Avatar
glide2meetu
Not sure but hope this helps.
http://www.jpcycles.com/instructions/pdf/AirCleaner.pdf
Old Mar 18, 2013 | 02:11 PM
Lowcountry Joe's Avatar
Lowcountry Joe
It all depends upon the design of the air cleaner and how it attaches to the breather ports. In the case of my Fuel Moto state one air cleaner, yes, I had to remove that bracket.
As I recall, there are two Allen screws on the back side that are a bitch to get out. Just find a short-shanked Allen wrench that will fit them and take your time. Of course you can always tilt-up the gas tank for easy access, but that may take longer. I just used an appropriate Allen and took my time. Then used a black cable tie to simply ball-up ad tie the cabling lying behind the bracket just to keep it all together. You will be surprised at how heavy that bracket is once you get it in your hand. After that, the rest of the install is a breeze.
Old Mar 18, 2013 | 02:16 PM
bberck's Avatar
bberck
I did on my SE breather. I took out the back bolts on tank to lift it a little to get to the bolts.
Old Mar 18, 2013 | 02:55 PM
TNCarters's Avatar
TNCarters
Had to remove it on my older FuelMoto high flow air filter but think I read they had redesigned the mounting for the newer breather that do not require it to be removed.
Old Mar 18, 2013 | 03:00 PM
mrfikser's Avatar
mrfikser
and make sure you get a good bite on those 2 bolts as they a tight as all get out...it was all I could do to get them out, I ended up raising the tank enough to get a allen that fits on a rachet in there...if you remove the rear bolt on the seat and stick a piece of 2x4 under the bracket for the back of the tank that should give you enough room to work
Old Mar 18, 2013 | 03:08 PM
Keithhu's Avatar
Keithhu
Really? My instructions were explicitly to leave it on.
[edit] - ah, just read a post that stated there's a newer design that requires you to leave it on, and mine's new
But glide2meetu answered your question by pointing to this pdf in his post - so no, you dont have to remove it for the RSD A/C
Old Mar 18, 2013 | 03:45 PM
Lowcountry Joe
Originally Posted by Keithhu
there's a newer design that requires you to leave it onA/C
True, but mine was the old model I guess. I had forgotten that FM came out with a newer model that no long requires it's removal.
I would think the OP should read the instructions that came with the unit to see if it answers his questions.
Old Mar 18, 2013 | 03:58 PM
Keithhu's Avatar
Keithhu
Well, there's that too, LOL
Old Mar 18, 2013 | 06:41 PM
cryan9's Avatar
cryan9
On my instructions it said to leave it on for 08-09 models. I called RSD and they were clueless. My bike is a 2012. The thing is I think it's ugly and want to take it off.
