Intermittent P1356
Intermittent P1356
04 FLHRSI with SE 95", heads, 257 cam, intake and D&D 2-1. Did a 300 mile ride Saturday and the bike ran great, but the CEL kept coming on when climbing gradual hills. I pulled the code when I got home and it was a P1356, rear cylinder misfire. I did not feel any miss, the power was smooth and strong, normally a miss is very evident on a twin. The light comes on pulling a hill or accelerating, usually over 55mph. I pulled the plug out and checked it, cleaned some of the anti-seize off and made sure the boot was connected good, still getting the light. Got screamin eagle plugs in it. The bike seems to have a pretty good tune on it, has some decal pop, but not very loud, I assume some of that may be from the cam overlap. Any ideas?
Plug, plug wire, or coil. About the only things that affect ion-sense - which throws that code.
Go hand over hand on the plug wire to ensure it's in good shape and pull the boot at the coil to make sure it's not rusty or full of water.
Beyond those simple checks, might be time to start changing those three things out starting with the plug.
https://www.hdforums.com/forum/ignit...ally-mean.html
This probably has nothing to do with your issue, but I found the link above interesting maybe worth the read. The year modles are close to the same. Good luck with your issue.
Yes, this happened to me. Check fuel pressure.
see:
https://www.hdforums.com/forum/touri...ml#post9200215
see:
