stock air cleaner over screamin eagle
I have the Screamin Eagle stage one air cleaner kit on my 03 RK classic. Its a cool looking breather but I hate the noise I hear out of it. The HD dealer I purchased the bike from said the stock outer cover will go over top and it does and I don't hear that awefull sound however I'm wondering if it defeats the purpose of the high flow breather. It does not touch the filter in any way but I'm wondering if it restricts the flow and is a hinderance to the bike breathing the way it should be. I have kerker high flow mufflers with the stock cross over. I don't mind the look of the stock outer cover. If it is an issue are there any high flow breathers that don't have that annoying noise they make.
randy
randy
the stock football cover will muffle the noise some- used they run about $35...my local classifieds is always maggoty with them.
as long as it will work with the filter you have- mounts on a center bolt
it'll block some, but it won;t muffle all the noise
I usually ride with my thigh tight to the tank, that blocks alot of the intake noise.
Mike
Mike
randy
randy
Good Luck
I have a Arlen Ness Big Sucker with a Alley Cat cover and you're right they are pretty noisy. My wife's bike has the same set up but the stock cover and it's much quieter. Both bikes are stage 1 and have DynoJet Power Vision tuners and I can't tell a bit of difference in power, (her's is a 15 Limited and mine a 14), between them. So i would say the cover will not limit the amount of air getting to the filter.
Good Luck
Good Luck
Has anyone tried putting a 2014 or later cover? Does it cover? (The Kury looks just like the Arlen Ness but has filter material on the top too....)
Stock air intakes provide many purposes. When you move from stock, you comprise some of them.
1. Reduce blow back flames from carb backfires. Keep from burning rider.
2. Reduce intake noise to below specifications set by manufacturer and government.
3. Filter the intake air to protect engine and intake electronics.
4. Decorate the motor.
This is one of the reasons that often the aftermarket can flow better than OEM. They do not need to address these restrictions.
I can't speak for the others, but my gripe is at idle. That is when the stereo's attenuation kicks in and the pipes are reasonable. The annoying reversion sound is louder than both and gets on my nerves like a nagging wife.... someone else's wife, that is.
I have a Kury free breather with the Alley Cat cover. Yes, the reversion is noisy.... Personally, I just don't like the look of the football cover.
